LMC Factory Tach
1987chevybad
New England
Alan
Has anyone used the LMC factory tach add on? Id like a factory tach in my truck and was wondering if anyone had anythoughts
J Knight
Baytown TX
82 Chevy
350ci
The LMC tach is a replacement tach for a tach cluster. It doesnt work with a stadard gauge cluster.
1987chevybad
New England
Alan
Too bad my trucks an 87 it says it only works up to 86
1987chevybad
New England
Alan
Really, because 87s are fuel injected and electronic
Green79Scottsdale
G.R. - MI
Bob
Unless you have a distributor-less ignition, it will work. All the tach needs is a signal from the dist. to register RPM. Fuel injection has nothing to do with it.
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
I've been wondering about that tach/fuel gauge unit too. Is there something different about the back of the 1987 and up VSS clusters that makes them bill that unit as only fitting 1986 and lower? I haven't pulled the cluster out of my 91 Burb yet to look, but it would be really cool if I could install that tach in it - just don't want to spend $200 on an experiment....
marks86
Latham, NY
Mark
12v Cummins
not to hijack this thread but did they ever made factory diesel tachs that reline at like 3500
diaric
Alberta
Richard
6.2 L
They made them for the med duty trucks. Lots of threads on installing them, no info on the correct signal to make them work.
Most of them ran off a flywheel gear tooth counter.
marks86
Latham, NY
Mark
12v Cummins
the ones with built in fuel gauges right?
Im saying could someone go to the dealer to buy a brand new truck and check off the 6.2 diesel box, along with the tachometer box?
diaric
Alberta
Richard
6.2 L
no they coildn't
mattyb
