Lift recommendations.
Strick
Dunn, NC
Harold
C20 Crew
Yeah, that rear shackle looks a bit sketchy! I've seen those offered in the replacement aftermarket fortunately. I just bought a K30 a few weeks back with some rigged up shackles similar to what you have. Hmmm...
Strick
Dunn, NC
Harold
C20 Crew
Here's how the guy's on the east coast of the US did this K30 wrecker.
molus
new zealand
morgan
k20
Looks all good from here. Mortal enemy of the cable tie.
Strick
Dunn, NC
Harold
C20 Crew
Look how both the front & rear shackles were modded!
Strick
Dunn, NC
Harold
C20 Crew
They used this truck like a mule out on the coasts pulling stucks out. The NP205 is even twin-sticked to lock out either the front or rear for maneuvers. Still, IDK if NCDOT would have passed it on inspection. NCDMV sure did...
molus
new zealand
morgan
k20
Im trying to work out my current lift. Can anyone tell me the stock measurement from axel to chassis on front and rear thanks.
I can't give you a stock measurement... but looks like 4-6" to me. Most likely 4. The front looks like it would only need these to fix it up.
https://www.offroaddesign.com/hd-front-shackle-kit-for-67-91-gm-trucks.html
The rear could be done with just a shackle flip and remove the block.
https://www.offroaddesign.com/catal...for-73-91-gm-square-body-trucks/category/487/
molus
new zealand
morgan
k20
I
I was thinking of doing this for the moment. Seems like shocks and everything else is already there to support 4 inch lift. I just read that the stock height from axel to chassis is 8.5 and I’m at 13.5. Likely I have a 4 inch lift and then they’ve extended shackle for a little extra.
Maybe take a leaf out for a little more flex and softer ride.
Hogger
Benson AZ
Steve
Whatever you do it's gonna turn a lot of Kiwi heads. Handsome rig!
molus
new zealand
morgan
k20
So I’m ordering some HD shackle flips from ORD with Some HD front shackles.
I’m going to take a couple of leaves out and get a local spring shop to reset the height. Hopefully that equals same lift + soft ride and more flex.
adhkjashda
