Legs TOO short. Need side steps
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
After all this rain passes by I'll crawl under and get a few pics.
Can't explain why I didn't do it when I was fabbing and putting them on.
Thankyou much, I will look forward to seeing them
bravo16
Prescott AZ
Amy
K1500
has anyone found a way to mount bully steps on a square body with dual tanks?
Craig 85
Nashville, TN
454/TH-400/NP205
Are you referring to this style? I used a 90 degree adapter on my drill. Easy install.
bravo16
Prescott AZ
Amy
K1500
Yes, thanks. Does the rocker panel bend at all? can you post close up photo of mount? .. nice truck btw, is it leveled?
Craig 85
Nashville, TN
454/TH-400/NP205
This was my last truck. The weight carrying part of the mount bolts through the pinch weld at the bottom of the rocker. There is a self tapping screw that mounts into the rocker sheet metal to hold it in place at the top.
This truck was level with the lift. They were Tuff Country 4" EZ Rides in from with Original OEM springs and a 4" block in back.
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
This is the best a 70 year old fat ****** can do...
Hope they help. You gotta get creative.
eskimomann209
Modesto
Marcus
That’s what I always called them. “Self tappers” dunno maybe my dad always called them that. But I get **** a lot. Usually ends up with someone telling me they’re self drilling screws. I usually end up telling them to self-screw themselves.
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
Colin, thank you for taking the time to post up the pic's of how you mounted your boards, man those really look nice and beefy, kinda like the rock sliders that the jeepers run.
I also like the idea that they will add a little protection for the gas tanks from any side impacts.
I am inspired, at least now I know that this can be done.
Thanks again,
Tracey>>>>>>>>>>>>>>>>>>>>>>>>>>>>
joshs74nova
