Knock sensor removal
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Has anyone had a problem removing the knock sensor from an 87 350 engine? Socket wont work, dont really want to vise grip the thing.
gb-00-87
Houston,Tx.
Greg
Did you try SOAKING where it is threaded into block with PB blaster? 87 had the round metal sensor with the hex drive on the plastic end if I remember correctly. Good luck, hope it comes out without to much trouble.
circuitguy
Elk Grove, CA
BIG-C
I soaked it with wd40 for two days then used a huge vise grip to get it off. Thanks for the advise..
Wrenchersllc
