keeping dual tanks
putt2014
Turbeville SC
Frank
How do I keep dual tanks when doing a ls swap. To my understanding the original tank selector valve can't hold the added pressure of the ls fuel pump. What is the best option for retaining the use both tanks.
gmachinz
Harnessworx Inc
Iowa
Jabin
I have an LS dual tank harness using a Pollak valve rated at 65 psi. My harness kit utilizes a main IGN control relay which triggers the selector switch and it flips a LH or RH electric pump. Walbro makes a nice fuel pump to add to your stock 87 TBI sending units. Relays mount underdash near fusepanel and everything else wiring wise is updated to run dual electric pumps.
I offer the harnesses for $289 if interested.
gmachinz
Harnessworx Inc
Iowa
Jabin
Here's another pic....
dougbert
5535 feet in Utah Mountains
doug
K1500/nv4500/np241c/33x12.50x16/4.10 Gears 14BFF
5.3L - 2002 Silverado, rebuilt top end, long tube headers
NICE
I will keep your contact info for when I put back in a second tank. Need to get it running on the first tank at the moment.
thx
dougbert
putt2014
Turbeville SC
Frank
Looks good. But what kind of fuel lines does it require?
rodneyrlegend
Rodney
Stock 6 port valve is ok in LS service. I am currently running this setup right now with no issues. I used earls fuel injection hose where needed with fuel injection hose clamps. 4 months, so far so good.
Gord
