Keep Frying HEI Coils PLEASE HELP!
olnick
Milford NH
Nick
c15
1982 350 4 bolt mains
Put a dwell meter on and I'll bet that the dwell is at MAX all the time. (dwell should change with RPM) Yes it will run however it will cook the coil quicker than you can say "oh ****"!!
Olnick
Olnick
i thought dwell was points only?
potent rodent
indiana
butch
86 and 78
350 and 305
make sure the black ground wire is is also connected to the inner ground strap
No, dwell is in all ignition types. It is the length of time that the coil is charging. All coils need to charge. In a points system, the dwell is set mechanically using the points. In an HEI system, the ignition module is automatically determining the correct dwell. If the module is bad, you can have crazy dwells(either too short which gives not enough spark energy or too long which can overheat the coil)
MikeB
North Texas
My coil was acting up and since the dizzy was 40 years old I checked the shaft freeplay and it was too badly worn to just do a coil.I put in a msd streetfire distributor,came complete and popped it in and for about the last 5 years it runs great.$175 at Summit.
Very good idea. The MSD Streetfire is light years better than the low-end cheapies. Also, a GM 93440806 doesn't cost too much and works well. It probably has a bit too much vacuum advance, but that can be modified. in 25+ years I have used both of these as well as Accel and stock distributors. None has every failed me.
MikeB
North Texas
As far as voltage, it was a couple of days ago. But if I remember correctly, I was at like 14.3 volts with the old alternator (running at high idle). That seemed on the high side for me, so I removed it and took it to the store. I replaced the alternator with a new one and the guy at the parts store tested both the old and New alternators. Both tested fine, but the old one sounded funny. Like it sounded like a piece of sand or small particle was loose inside the alternator. So I replaced it anyway just to be on the safe side.
Alternator output voltage is regulated at around 14.2 volts. However, with the path the current must take to get to the coil (bulkhead connector, ignition switch, bulkhead connector again), you might find anywhere from 12.0-13.5 volts at the coil. I've seen less than 11 volts on old cars with worn-out switches and connectors.
Glad you got it fixed. Hope it runs well for a long time!
why thank you for the explanation!!!! I do appreciate it :) best not to dwell like the eagle man says
usnrcwo
Oklahoma
Robert
1500 Sierra
Morning, I am having the same problem. Does anyone have a diagram or photos showing where all the grounding wires should be. I haven't thoroughly checked the ones I know about yet but will be doing that this weekend as I fried another rotor/button. I'm particularly curious about the frame to body ground as I don't recall noticing one anywhere unless its there and I didn't realize that's what it was.
crpntr78
Missouri
I know there's at least one frame to body ground under the bed.
SirRobyn0
Rob
I know the OP got it fixed, and I'm seeing this late but for anyone that reads this and is interested in knowing, we do quite a bit of work on squares and other older GM vehicles at the shop, this is how we would troubleshoot a problem like this. If the symptom is stalls and won't re-start or re-starts later, something of that nature and it's not a fuel issue. We'd attempt to test the module by looking at dwell, but even if the module passed testing if it looked like it was age old we'd replace it and retest, in the OP's case of a melted coil we'd do module and coil. If after that it still did it we'd replace the entire distributor. We are talking about 40 year old rigs here and after all that time and mileage there are to many what ifs and potential marginal parts, sloppy bearings, worn gear, pick up coil, advance springs. not that all of those things will cause a stall out, but once you have replaced the easy stuff, it's better I think for long term reliability to just replace the distributor. A/C Delco still makes them new, if for some reason we can't get one quick enough Duralast Gold New (not rebuilt!) units from autozone have been great as well.
Octane
Atlanta
Eddie
Yeah,and for about $175 bucks I bought a msd distributor. Good deal considering costs of replacing the individual parts and still having a 40yo dist.I've gotten great service from mine.
SirRobyn0
Rob
The ac delco units are about the same in price. I guess it all depends on your preferances
Madmacs
TN.
Dave
K10, K20
I have been through this before , go buy a new Delco distributor , and move on. Problem solved.
