K10 lift on K20?
JRandle
Verden, OK
Chevrolet Silverado
I'm sure it's been asked.. but I'll ask again [emoji85]
Will a 6" lift for a 1/2 ton work on a k20??
Rear will have blocks so I'm worried about front only.
Stewzer55
Ohio
Stew
R30
I'm gonna take a quick stab at not giving a good answer, but if the spring dimmensions are the same than it should. With the front axles being different only at the hubs between the K10 and K20, I'd only suspect spring length to be the issue.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
The fronts should fit just fine. The rear is a different story, I believe 3/4 ton trucks came with 56" rear springs, most 1/2 tons came with 52"
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
I believe he is planning to run blocks in the rear, so spring length in the rear likely will not matter.
JRandle
Verden, OK
Chevrolet Silverado
That's what I thought too. Had a couple buddies tell me otherwise..
I think I'll buy the 6" lift that I can get my hands on
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
What axle is in the rear of your truck? You may need different U-bolts if you have an axle with larger diameter axle tubes than a 10 bolt axle.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
You will need larger rear U bolts. The K20 axle has a larger diameter.
JRandle
Verden, OK
Chevrolet Silverado
I'm looking to buy the truck. It's an 85 k20. All stock so I assume it's a Dana 44 and 14bff?
The rear I'm just gonna use a 4" block.. the front I believe is the Dana 44.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
If the rear is a 14bff you will need longer u-bolts specific to that axle. 1/2 ton trucks came with a 10 bolt axle that has a smaller tube diameter, so the u-bolts that come with a 1/2 ton lift kit will not fit around the tubes of a 14bff. The only way I can see you getting away with not having to get different u-bolts is if the u-bolts that are currently on the rear axle are long enough to accommodate a 4" block and still have enough thread to get the nuts and washers on. But I think that is a slim possibility.
JRandle
Verden, OK
Chevrolet Silverado
I see what you're saying! Shouldn't be hard to find larger u-bolts. I am more worried about the front lift springs working or not.
dbarham78
