Just got first squarebody, joined forum because I need help!
emtrichel
Laguna Niguel, CA
I just got my first squarebody, a 1979 Chevy 1500. Its in.. decent shape. Seller disclosed a coolant leak, and pointed out that it was coming from a crack where the lower hose (from radiator to engine) meets the engine. After overheating, parking, and letting it cool, I added a gallon of coolant - to watch it completely pour out from.. somewhere. It is not leaking from the crack from what I can tell. I will replace that hose - but if the overheating/leaking continues, I would be at a loss on where to even start.
Preston
Mechanicsville VA
Preston
Welcome to GMSB from Virginia
Post a picture of your truck, leak we will help you get it fixed
:grd:
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Get some leak dye for your radiator and a UV light. Autozone sells it.
1973c10
Don
:welcome:
eskimomann209
Modesto
Marcus
If the truck doesn’t exist, then how too can the leak?
Translation
Pics or it doesn’t exist !!!
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
coming from that area there are a few possibilities
lower hose if that's leaking it should be obvious.
water pump use a mirror to view the underside of the water pump. there is a weep hole under the pulley if coolant leaking there the pump is bad'
other possibilities would include a freeze plug head gasket or intake manifold.
my moneys on the water pump
:welcome:
eskimomann209
Modesto
Marcus
I thought you meant because there was no 79' 1500....
Is true. Much like when people have an 89 c10.
I tend to let them go for those mishaps. Besides ..... he’s (she’s) still new
Green K10
