Joys of the 10 bolt
emsherer
TN.
E.M.
For what it's worth a wrap of Teflon tape on the threads and some white Teflon pipe dope on the tape then tighten "snuggly" is my procedure. The tape gives resistance to back-out and the pipe dope will cure to stop vibrating out but won't have to be heated to remove. If you do use locktite make sure it's the blue
DBeck350
North Carolina
Darren
I actually used this a couple months ago and it works perfectly. It’s good to have in the tool box if you own a 10 bolt. Worth every penny.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
You guys are lucky...mine removed itself without my approval:rotflmao:
Yea I did that once. Did it ruin the driveshaft too?
PrairieDrifter
North Dakota
Mason
Nope driveshaft is fine. I was doing about 25mph while on decell for a turn.
I had wheel spin and was in the throttle hard, Drive shaft turned into a candy cane
RoryH19
Rory
R10 Silverado SWB
I think you may need a new one.
I haven't seen one blow up that much in a while.
85Shortsquare
