Intro and question about towing with a C35 one ton
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Do you know the GVWR for the truck is? Should be located on the drivers door sill (?)
Blake_496
Longmont, CO
blake
C35
that is not the stock color. the truck was originally a different shade of red. however - I believe is is 'a' stock color as my Dad's '77 was exactly the same.
After doing some thinking on this, I put an ad on my local craigslist putting it up for trade for a smaller trailer. I bought that big @$$ trailer from a buddy knowing it was a little too big anyway.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
I really think you will be fine with that setup. I would check with your DMV and insurance company from a legal perspective. But from a capability standpoint, you shouldn't have any significant issues pulling a gooseneck double car behind that badass truck.
It's better to have more trailer than you need, rather than needing more trailer than you have :cheers:
fussfeld
east coast
j
c-10
4.3 v-6 262CID
What's the GVWR for the truck?
Blake_496
Longmont, CO
blake
C35
My 2 concerns would be that stock radiator ..
yes
that was pretty much my only issue. The killer is that I actually bought a really nice aluminum radiator with twin fans on it, but it didn't have the extra port for the heater hose, so I ran the stock one.
Currently fabbing up mounts for the new rad...
Georgeb
Wisconsin
George
K10 Burb Z71
yes
You can run the heater hose to the water pump instead.....
Blake_496
Longmont, CO
blake
C35
no, the L18 uses a different style. There is an outlet from the water pump that goes into the heater, then the heater outputs back to the radiator. My new radiator simply does not have an outlet for that return line.
I don't need a heater for the near term and I think that bypassing it may actually help keep the cab cooler...
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Lu Blunt
Rye, CO
Luke
350ci
This is what I found.
THREE QUARTER TON 2WD SPECS:
Model designation:
1973-1986 Chevrolet: C20
1987-1988 Chevrolet: R20
1973-1986 GMC: C2500
1987-1988 GMC: R2500
GVW:
1973-1979: 8,200 lbs. single rear wheel
1980-1988: 8,600 lbs. single rear wheel
ONE TON 2WD SPECS:
Model designation:
1973-1986 Chevrolet: C30
1987-1988 Chevrolet: R30
1989-1991 Chevrolet: R3500
1973-1986 GMC: C3500
1987-1991 GMC: R3500
GVW:
Standard: 9,000 lbs. single rear wheel
Optional: 9,600 lbs. single rear wheel
Optional: 10,000 lbs. dual rear wheel
ONE TON 4WD SPECS:
Model designation:
1973-1986 Chevrolet: K30
1987-1988 Chevrolet: V30
1989-1991 Chevrolet: V3500
1973-1986 GMC: K3500
1987-1991 GMC: V3500
GVW:
Standard: 9,200 lbs. single rear wheel
So if you're a dually, pretty sure is 10,000 lbs regardless of rear axle ratio
Also a pick of my fsj. Love squares n jeeps
yevgenievich
Viktor
sad
very sad
less sad
Updating this regardingng gearing. I have been towing a small trailer(5k) with 3/4 suburban(same 4l80e) and to keep lockup happy was driving 70-80mph with 3.73 gears. Also have 1 ton with 4.11 gears and it was happier at lower speed than suburban.
Tommyutah
