Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
I've had one of these on my carb since about a year after they came out. The manf. says they will produce 10 to 15 horse power. But to be fair, even though some knot heads have tested it on a flow bench and said otherwise. Well, I'm sure their test was wrong but I can guarantee you it does produce horse power from the fact that physics is on it's side. I don't have a drag car to test out a open carb and one with this product on it so I can't say I've tested it on the strip. Unfortunately none are made for the Q-jet but there are plenty for all kinds of Holley carbs. There is one for a Carter AFB so if you have one of them I've included the number.
K & N 85-200 for Holley 4150 and 4160 4 bbl. $54.99 (Summit price)
The part number for the Carter AFB is K & N 85-0700 $54.99 (Summit price)
K & N "stub stack" It's designed to smooth out the airflow into the carb. As you know there are all kinds of obstructions around the air horn for air to get down into the engine and this item smooths all the air flow out thus producing horse power, because the air goes straight in with no turbulence. This also helps alot in improving gas milage as well! This is the one I have on my engine and it's part number is:K & N 85-200 for Holley 4150 and 4160 4 bbl. $54.99 (Summit price)
Here's how it sits over the carb air horn. It's made so it sits snugly over the horn so you don't have to ever worry about it coming loose inside the air cleaner. It slides down over the center bolt for the air cleaner and the bowl vents.
Another angle.The part number for the Carter AFB is K & N 85-0700 $54.99 (Summit price)
