- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Yes, needle likely fell off when you turned it over to dump the gas, it just hangs on there by the spring normally. The power valve hanger can easily get bent if the last person to assemble it didn't make sure the needles were lined up inside the jets before assembly. It's kind of a pain to get everything lined up and in the right spots in the air horn gasket while assembling it. If you slip and it slides out of the jet and moves a bit to the side, then it will jam up sideways and then get damaged when someone tries to keep bolting it down.I got the carb off the truck and apart today, got the air horn off ok. I poured the gas that was in there out. The power valve with the two needles was stuck and a little bent, and the needle valve was completely off and the wire spring that holds it on the float was off. How did that happen, did I do it pouring the gas out? don't think I bent the power valve part, and I think I got it straightened out ok, but maybe the needle valve fell off when I poured the gas out? I put it back together and hung it on the float, should I get a new one? Having trouble figuring out how to check the float level. I found a really good video that is pretty helpful but this is kinda scary for me. Not sure how I'm going to get the needles on the power valve into the jets, and I don't want to try until I know if I should get a new needle valve.
