77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
The arms are actually slightly lower- but just the act of flipping the tie rod from the bottom to the top moves it a lot higher. You can see the stock arm was pretty much lined up with the stud at the 10 o'clock position. The Reid knuckle it is probably closer to 9 o'clock.
Just got off the phone with ORD- they said that is common issue with the nut down style. They said adding the 1/4" axle relocation plate will give the required clearance. There won't be much, but it should work.
Ugh.
This will make the tie rod "trapped" in there. You can't lift it up and out because of the leaf springs. I guess I better automatically replace the tie rod ends when I drop the axle off of the leaf springs because it will suck to have to do this again.
