Johnnyz453
- Oct 6, 2016
- Jacksonville, FL
- John
- K10
I have an 83 k10 and im trying to get everything dialed after the engine rebuild. Its a Sbc 350 with a 4x4 cam, flat top pistons, dart heads, edelbrock performer rpm intake, and a brand new quadrajet bought off jegs.
Everything was running right but it was idling high in park but dropping when put in gear. Found out the cable linkage wasnt returning all the way and you could pull back on it to drop rpm. After giving it some throttle and then pulling it back a few times it finally is where it returns now.
The problem is now it idles at 500 rpm in gear and drops to 400 in gear and it doesnt want to stay idling when in gear. The idle screw is turned all the way in so i cant turn up the idle anymore. Dont know why it would be so low with the screw turned all the way in. Since the trottle plates are open more than usual because of the idle screw it wants to diesel when turning it off. Killing it in gear helped but still had a bit of dieseling. It was set at 10* initial but when i dropped it to 8* it seemed to run a bit better. NEED SOME HELP KINDA QUICK.
