Idle acting up
86suburbanNJ609
South Jersey
Aaron
Suburban
Drove the truck to get some smokes and I noticed the idle is a lot slower and deeper sounding then usual almost like a big cam lol. Throttle response and start-up no problem or change on highway over 50 same thing fine. Its an edelbrock 1406 and mainly stock. I've only cleaned the outside of carb with 2+2. My question would could cause this? It doesn't stall or backfire almost like a lack of fuel?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Maybe your truck’s telling you to quit smoking. Just kidding. Sorta. Since it’s a new thing, I’d do a once over of the vacuum system. Speaking of which, a reading for that would be helpful. Timing and tuning are the first things that come to mind. Do you know what your timing is and roughly what your curb idle speed and idle mixture are set at? Also, your compressor clutch isn’t engaged, right?
rt66paul
California
paul
1991 suburban
A bad fan clutch can give you a roar, as can a dry cooling system.
86suburbanNJ609
South Jersey
Aaron
Suburban
No
No vacuum system hooked up and compresser off. I An going to clean the carb out and and readjust this weekend.
SquareInheretance
