I might have messed up buying shocks. Pic's inside.
Nasty-LSX
TogetherforeverCovid19
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
I just got my KYB GAS ADJUST shocks. With the old shock still on I measure the mounting bolt from top to bottom
and its 12 1/2 inches on the stepside
Then I checked the 86454 truck and they are the same
Then I realized I have a big block with small block springs!!
How to I find out if the stepside has been lowered or not. I
dont think it has up front front I did put shackles in the rear.
but the truck is not low. I ordered factory ride height shocks.
So I want to figure this out before I install them and find out
they are wrong and cant return them LOL
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
here it is. I think its normal ride height. Whats it look like to you. Might look a little lower but because of the
shorter tire
bluex
Spartanburg SC
C15
Kyb 344068
These will allow the front to lay the a-arm an still not bottom out the shock (you'd have to remove the bumpstop first) there is plenty of travel in the oe replacement shocks for these trucks. Run these on the front for stock, dropped it don't matter. I've put many of them on an everyone is always happy with the ride.
bluex
Spartanburg SC
C15
KG5409 for gas a just. Collapsed 9.88" extended 14.88" your fine at 12.5, right in the middle.
That truck isn't lowered in the front, doesn't look like it to me anyhow
Agreed. that looks stock height to me
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Thats what Im thinking. Im just going to go ahead and install them. Thanks all!
millernf
