AyWoSch Motors
The Parts Guy
- Nov 6, 2020
- New Mexico
- Ayden
- K1500 Sierra
- 350ci V8
I just got my truck running for the first time in a year the other day, and after it sitting and me replacing and upgrading the clutch to a 12in instead of an 11in, now i cant drive it.
I can start it, if it's in neutral and clutch in, but I cant get it in gear. 1st, 2nd, 3rd won't go in, low just grinds. If you try to start it with clutch in and in gear, it lurches forward.
Obviously the clutch isnt releasing as it should. Clutch and pressure plate are brand new and installed correctly, release bearing is new and installed correctly, the clutch arm has been cleaned and lubed. I assumed it must be that there was air in the lines, so I bled the system in place, still nothing. I took the slave cyl off cleaned and lubed it, bench bled it, installed it, bled it in place, still nothing.
Theres no adjustment on the rod, no damage, nothing changed under there since I last drove it, other than bigger clutch, new engine, and year of elapsed time.
What could it be? I believe I did everything right. Could it be the clutch master cyl is bad?
Its driving me nuts. I've done everything I can think of doing, and I'm itching to drive the truck again.
Please help, I'm stumped.
