Humvee 37s
chevydude
arizona
hunt
k20
This is just a tip I thought i would post. the Humvee use 37 inch tires that uses bead locked rims. The way the rim is set up is that You could use for some axles but the rim pushes the tire way inside the fender wells. But you can get a shop to cut the center section out then put your steel rim inside of it. So when you do this then you end buying Humvee tires for about 80 to 110 dollars.Depending on what condition you want. Not to mention they are in good shape.
So just a helpful tip I wanted to put out.
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
I will be buying a set of 5 37 humvee tires here shortly with the stock bead locks for my crew cab. the place i found has them for 149.95 tire on rim. you need to run dually axles for them to clear and look good or use some 2 inch spacers, or have them recentered. For a recentered humvee wheel it is about 150.
chevydude
arizona
hunt
k20
Yah i have seen that too still it is good price compared to more than 300 dollars a tire for a good 37 inch tire. And i have seen it both ways. Both ways are still good.
chevydude
arizona
hunt
k20
Also I didnt know they sold recentered rims thanks for the tip
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
How bout some links to these places yall are getting this stuff?? I'm interested in some recentered H1's with the beadlock runflats and a set of 37" Goodyears.
elstm3
montana
lynn
V30 crew cab dually
I think they have the best deals and services. Also their tires are 75% or better on the good year radials, and they do all the wheel work in house.
http://www.trailworthyfab.com/
chevydude
arizona
hunt
k20
I found these tires at a local guy who gets a shipment. The re centered rims are at a local shop that does it. But if you are looking to run bigger tires these are the way to go
chevydude
arizona
hunt
k20
I would look at your local military stores and there are some private bushiness that own all the military trucks I would also check to see if there are any there.
8T6K5
AZ
L98 350 TPI
chevydude
arizona
hunt
k20
I do not have run flats but They run at about about 50 dollars at trail worthy.com they uses pvc cut to length. other run flats are supposed to tear up ure tire but the pvc works well. (so they say) I do not have experience with them though.
scawdrey
