How to lean a Edelbrock 1406?
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Y'all have brought up an interesting point about the fuel pump. The old 305 had a return line on the pump when I bought a new one. The truck has a line on it too. The BBC has a new pump but, it doesn't have a return line on it tho. So the line is just not hooked up.
So should I go get a new pump with a return on it? Would that help?
Yes.
dsteelejr
Hudson, WY
Never heard of valve covers without an oil filler cap. Pics?
Dutch rutter has one on the pass side back by the firewall.
I've always run stock covers. All I see is the PCV breather.
Dutch Rutter
Independence, Or
Joshua
@82sbshortbed and @dsteelejr
82 shortbed is right, I use the rear passenger side breather hole as an oil fill. I pull it out and add through there. Works well but can sometimes make a mess.
I have seen some completely sealed valve covers but I dont think you would want to run those unless you were building super high compression or adding alot of boost or someother reason that I have no idea about.
I do like this covers but the best thing I ever bought was these cover gaskets.
https://www.speedwaymotors.com/Spee...l-Core-Valve-Cover-Gaskets-Pre-1986,1872.html
Off-topic confession: I do wish that I would have gone with a 383 or found a 454 to build up but the .30 over 350 does well for what I need.
dsteelejr
Hudson, WY
After reading that I broke down and bought the covers. I'm normally not into engine dress up, but I thought these looked sharp. Wa going paint the engine orange, but after bringing home the reman I found that the engine shop already painted it black, so rather than fighting it I'm just roll gonna with black. Thanks.
dsteelejr
Hudson, WY
@82sbshortbed, wondering if you made any headway on getting that Edelbrock tuned up.
The other day I was thinking about this thread and I touched on the first step, which is getting the fuel pressure correct, but neglected tuning it afterwards.
Here’s a quick vid on getting Edelbrocks tuned. I follow this guy on YT. He’s a Mopar fan and he loves cars, not so much trucks, but he is old school and has a lot of great advice and how to’s that apply to our old school trucks.
Moose Drool
Southern Oregon
K1500
Bringing this back up with a question......
I am looking into putting in a return style regulator. I have a two port mechanical pump, in/out. What is the best/easiest way to plumb in a return line?
Dutch Rutter
Independence, Or
Joshua
Easiest would probably be to go to a single out port fuel pump and plumb the return line from the regulator to the return line that currently goes from the pump.
Edit: Just re-read your post and saw that your pump is a return-less style not the return style I thought I read it was.... my bad.. You'll be in the boat of running a return line all the way back to the tank.
Camar068
10 yrs Air Force
I read somewhere that someone spoke to Edelbrock tech support. In that conversation he said 2-5 psi fuel pressure. I never got to try it on mine as I ended up installing a Demon carb.
Moose Drool
Southern Oregon
K1500
Is there a way to tie the return line into the selector valve? Or just the main tank?
Dutch Rutter
Independence, Or
Joshua
I have not heard of a way to route it to the selector valve (I could be wrong here) but I believe most go right to the sender on the tank. Which i would also think might require changing depending if yours have the port for a return or not.
Also edelbrock says they have a max of 6.5psi I have mine set to 4.8-5 they tend to get a little finicky over 5.
Moose Drool
Southern Oregon
K1500
Thanks for the info. I have dual tanks p, so I will have to do some more thinking about b doing a return.
Dutch Rutter
Independence, Or
Joshua
Tbh I'm not very familiar with the fuel lines on our trucks from the selector back. There might be a return line there somewhere. The pump on my 83 with dual tanks is a 3 port type. And I used a regulator with a return but just plugged it off there. 2 years now its been working fine that way.
(Knock on wood)
Moose Drool
Southern Oregon
K1500
(Knock on wood)
What pump are you running? That might be the best/easiest way to go.
Dutch Rutter
Independence, Or
Joshua
@Moose Drool
It's just an over the counter kind from NAPA. Nothing fancy.
Edit: if going that route you'd still have to run a line from the pump back. Would be cheaper to get a regulator with the return, keep the 2 port pump you have, and run the line all the way. Instead of buying the regulator, 3 port pump and then running the line.
aaron06
