How do I know if I have HEI, and if I don't have it, should I upgrade
MisterB
Northwest
AJ
GMC K2500 4X4
I have a crate 350 motor in my 1980 GMC K2500 4X4. I'm going to swap out my spark plugs and spark plug wires. My cap says Delco Remy. Is that just a traditional cap, or does it have HEI? I need to know so I know what to set my plug gap at.
If I don't have HEI, should I fuss with upgrading everything to HEI? What would I stand to gain?
Sent from my SM-N975U1 using Tapatalk
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Hei is big and bulky, has a coil within it, you will see a rectangular shaped module in the top of it. It has just 8 points on it.
If it is not hei, it's just a regular cap, with the 9 points on the top of it. And the middle point runs over to a coil pack, somewhere on the motor (valve cover usually)
HEI is generally significantly higher voltage in comparison to just a coil pack,
As a "general" statement /overview
Hotter spark = more power
And that's very very generic explanation
Sent from my SM-G965U using Tapatalk
MisterB
Northwest
AJ
GMC K2500 4X4
Yeah, thanks pal. I did that first, but would like more of an explanation than I was finding, similar to what the guy above you provided
CSFJ
You seriously have never noticed the difference between a points/condenser distributor, and an HEI distributor?
CSFJ
Again, you couldn't tell the difference?
MisterB
Northwest
AJ
GMC K2500 4X4
Again, quit being a dick. Prior to asking this question, I did "Google", and it appears GM started offering HEI at some point. I wasn't sure if a stock GM HEI looks different from an aftermarket HRI. Mmmmmm k?
CSFJ
You must be fairly new to GM vehicles.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
To add to that. points wear and go out of adjust, needing to be readjusted or replaced. With HEI you set it and forget about it. I would switch to hei on any shock and mild built chevys
MisterB
Northwest
AJ
GMC K2500 4X4
Good point. I appreciate it
Vbb199
Salisbury NC
Vince
As a good unspoken rule here on the forum, there's guys here that'll give you **** and be *********, if you show distaste in it, they'll continue to do it,
go along with it, they won't continue to do it, just friendly advice
We got some "gasoline on the fire" guys here
MisterB
Northwest
AJ
GMC K2500 4X4
I would know, I'm like that myself
I don't think you're like that, or you wouldn't have taken the time to give a helpful response.
These other jokers can kiss my ass.
Mousta5
