Hood Project Opinion
Preston
Mechanicsville VA
Preston
Bought this yesterday $30.00 thoughts......the scoop is glued on need to remove, the peeling clear coat can be removed with sand paper or scotch brite. My truck is dark blue the hood is black what would you do?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
For $30 I'd clean it up and see watcha got.
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
As long as you don't spend more to repair any defects then what it cost to get a new hood its a win in my book.
86Peter454
Missouri
C10 Scottsdale
be careful when removing the scoop.
just keep your tool parallel to the hood and dont pry on it. you will dent the piss out of the hood if you do.
78C10BigTen
pennsylvannia
C10 BIG TEN
I woulda grabbed it for 30 too. Id pull the scoop, cheap paint it nicely, reattach the scoop correctly and run it.
varmit86
Washington
Mark
C30
Why pull the scoop? these hoods are very weak sometimes folding in the middle when shutting the hood. This scoop will give it extra strength because of the vertical lines. Unless you really hate it. Once cleaned up will give it character.
Preston
Mechanicsville VA
Preston
Think I could use a piece of nylon string (like dental floss) and get the adhesive to let loose?
varmit86
Washington
Mark
C30
If it was done right with the new adhesives out now your going to need piano wire and a pair of leather gloves.
Is the scoop the type with an inside flange?
Super-Dave
Dave
Was the scoop just for looks or did the PO cut a hole in the hood?
Preston
Mechanicsville VA
Preston
Will paint stick to the scoop ,it’s plastic. Or should I tape it off and leave it black as is? I picked up the proper sandpaper to clean up the clear coat may just have to spray a couple coats of clear f I don’t go too far. If I do well I’ll get some dark blue and see what I can do.
Preston
Mechanicsville VA
Preston
I installed my hood yesterday(by myself) not perfect but I like it (I’m not a painter) gonna drive it like I stole it transmission th400) is shifting great flexplate fixed a/c blowing cold what more could I need.
Misty Blue
