- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
I tested my hood with a Magnet. It Stuck, So It seems my Orig hood was never messed with/nor an Emblem.
I can tell it's orig b/c the midnight black paint is still on it. But the only real way to tell is Contact GM media archive and get the Info packet...
With modern lightweight fillers, the magnet trick doesn't work well. Unless it's THICK. It also could have been welded up and metal finished.
Just look at the underside of the hood, where you would access the retaining nut for the hood ornament. Previous work should be easier to spot that way.
