High cold idle
Burban1990
Vancouver, Wa
James
Suburban 2500
My 350 runs great but I feel the cold idle runs a little too high. I understand it's supposed to be that way while it's cold but it's a little too high. What's the best way to lower the idle for when it's cold on a throttle body? When it's warm it's fine.
Try to do an IACV relearn before doing anything and see if that does anything. You jump the A/B diagnostic terminals, key on, wait 45 seconds, unplug the IACV connector, key off, jumper out, replug the IACV. You can also (gently) clean the carbon off the valve pintle and check for carbon packed in the idle passages underneath. If that doesn’t work, expect that you have a cold vacuum leak that’s sealing itself a little when you get warm. Possibly base gasket or throttle shaft has worn into the TB, which would require a bushing to be installed. If the vehicle has more than 150-175K miles, it’s getting worn already. Cold and hot vac readings would be helpful to check for disparate values. You can check base timing, but I’d do that later, and only replace the IACV when you’ve exhausted all alternative.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Temp sensor or IAC faulty
Replacing Iac will require relearning idle by setting it manualy
^^^ CTS is another. I’d want to see serial data to see if the sensor was sending back actual temp confirmed by a temp gun at the sensor site. That’s fifteen dollars that I’d rather not waste if you don’t have to. You could also see IAC counts. Most people don’t want to make the scan cable, and while it’s cheap insurance to replace the CTS, I hate to throw away a good GM part (assuming original) for China’s finest.
Burban1990
Vancouver, Wa
James
Suburban 2500
Thank you for the response I just want to make sure this is the correct diagnostics terminal for my truck.
Vbb199
Salisbury NC
Vince
Yes
Burban1990
Vancouver, Wa
James
Suburban 2500
One more quick question when the idle is high when you first start the engine being cold at what temperature does the idol drop down to normal?
gmbellew
Kansas city
glen
suburban 1500
for a 350 TBI, I'd recommend getting a bluetooth aldl reader and the aldldroid app. it lets you see what all the sensors see, for an all in cost of about $100. I can send you the file I found to use on my 1990 burb with aldldroid.
Burban1990
Vancouver, Wa
James
Suburban 2500
Can you send me a link to the Bluetooth aldl reader? I'm not sure what I'm looking for. Is it made by red devil River?
Idle speed should begin dropping within a few seconds of startup, but I’ve never timed how long it takes to settle to about forty counts just sitting there.
Burban1990
Vancouver, Wa
James
Suburban 2500
That's what I kind of figured
My high idle lasts for much longer at least until I put it into gear. I try to let it warm up so it doesn't slam into gear when going into drive or reverse.
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
CTS most likely is reading bad wrong.. you can test it with a simple multitester. there is a chart all over the internet that shows resistance measurement at certain temps, for these CTS, they do fail and can go innacurate. they dont last or work for forever. ive had to replace many,. im pretty sure its higher temp lower resistance. the ECM sees resistance value and converts that value to a temperature. a certain value is a certain temp. which determines fuel and idle speed and etc. combined with other sensors as well. and CEL codes 14 and 15 are CTS ones. thats one flash and 4 or 5 flashes, of the CEL lamp, in CEL lamp/ECM diagnostic mode, at the ALDL connectors
Burban1990
Vancouver, Wa
James
Suburban 2500
Yeah that feels right because computer not getting correct temp readings and continue at higher idle. Thanks for the heads up. Gonna due a reboot first as suggested and if no success will move on to this.
3dbello
