hey stereo people
colonel mustard
louisville ky
steven
k5 blazer
so I have a 82 k5. I recently put new 6x9 in rear and new what ever size in the dash. I have a pioneer dep-5000 head unit. the 6x9 are not in any kind of sealed box (should they be ?)
a couple questions. I'm looking for more low end noise. bass. it doesn't seem to have any really to speak of. I have messed with the equailizer and setting a lot. just doesn't seem to do it. do you think its because the 6x9's are not sealed? am I missing something? I'm not looking for crazy bass....but it would be nice to have some. I have ran this set up before in cars and it sounded great. thanks
head unit pioneer dep-s5000
front speakers kicker 3 1/2" 30watt 2 way
rear speakers blaupunkt 6x9 450 watt 4 way
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yes an enclosure will help a lot. There are free air subs, but 6x9s aren’t in that category.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Yes. Your 6x9's need to be in a sealed box to get them to get the maximum amount of bass out of them. You can buy some already 6x9 boxes for cheap. I've got 2 6x9 boxes and they sound really good.
Here's a pic of the 6x9 box I have in my camaro. As you can see I have since installed a 10 inch sub in the truck also. I like a lot of bass in my stereo system but, before I put the sub in the 6x9's bass was good(I just wanted more) but, might be the right amount for you. In order to get the full sound out of them you need to have them in a box. If you don' want to buy the boxes you should definitely build you some. Or make one to mount both of them in. Either way put them in some type of sealed box or boxes.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If you build one to mount both make sure there is seperation between the two. Sound quality will take a header if you don’t. Specific volume is of importance too, to achieve good sound.
Craig 85
Nashville, TN
454/TH-400/NP205
How are your 6x9's mounted? In my '77 K5, circa 1992, I had 6x9's in the bottom of the front doors (manual windows) and another set mounted vertically in the rear side panels behind the driver's seat.
The PO had removed the side panels prior to my purchase, so I had new ones made when I re-did the interior. We used a thicker plywood that the 6x9's were mounted to. I also added 3 or 4" dense foam between the metal body and side panel (this is long before Dynamat). I left room around the speaker for some air to move. Had plenty of base.
colonel mustard
louisville ky
steven
k5 blazer
thanks for the feedback guys. ill get them sealed. pics to come. do you all think I should be using an amp for my 6x9 ? the are 150 continouis watts and 450 max watt
yevgenievich
Viktor
sad
very sad
less sad
insulating the dash helps the tiny speakers in the front as well
82sbshortbed
Fuckemall!!
SE Texas
Doug
Yes I would. You have some good 6x9's with a high continuous watt. 150w rms is really good. So you need to put close to that wattage to them. If you get am amp that puts out close to that per channel. Then you can turn the gain at about 3/4 of the way up and that will keep distortion down. Which allows you to keep you from having to turn volume knob way up which also reduces distortion. My Kenwood system in the camaro is not turned up over 20 to 25 and it's max volume is like 35 or so. At 20 to 25 it's nice loud, clean, crisp sound. Because the more to have to turn it up the more distortion you will put in the system. I would just hook your dash speakers up to the deck. That will probably be enough watts for them and get a 2 channel amp for your 6x9's.
colonel mustard
louisville ky
steven
k5 blazer
thanks for advice. so when I'm looking at amps...a 400 watt 2 channel would be good? I found one that says its max power is 400 watt bridged. so am I safe to say its 200 per channel? sorry for the ignorance....I'm not too savvy on audio stuff yet.
WFO
Texas Panhandle
Even a 40 or 50 x 2 amp would be plenty to push those speakers.
82sbshortbed
Fuckemall!!
SE Texas
Doug
No problem man. I'm glad to help. I know more about stereo systems than I do about working on the engine and other things on our trucks. Lol. That amp would be a good one for your 6x9's. Because you won't have to crank the volume to push them, keeping your distortion down. Therefore your music will be much cleaner.
yevgenievich
Viktor
sad
very sad
less sad
Generally amp should be decent as an amp that is pushed will produce cliping and bad thd, which will overheat the coil and damage the speaker.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Make sure you amp and speaker impendence ratings are the same
coffeeguy
