Hesitation wonder what to do 1985 k10 sbc350 has hesitation when easing in to throttle mainly between 1st and 2nd gear supposedly Rochester was rebuil
Brcktman
Los banos
Bruce
Crew cab
None
Hesitation!!!! What to do 1985 k10 sbc350 has hesitation when easing in to throttle mainly between 1st and 2nd gear supposedly Rochester was rebuilt but not sure have rebuilt carbs before but never a Rochester
SquareRoot
Judging from your signature block, the engine size might be the problem? Joined in 17 and this is your first post...also impressive.
FireTruck1984
Michigan
Ted
1984 and 1984
You‘ve won the award for having the longest Forum Headline Ever! ;)
WebMonkey
Missouri Ozarks
forums are brutal!
i'd reply but i don't want to wait 5 years to find out if i was correct.
xtra :)
'monkey
fast 99
Spokane, Washington
First check all the tune up items, plug condition, fuel filter, air filter, timing, both advances, vacuum leaks, ect. After that engine not running look down front ventures for a decent squirt of fuel when throttle opened. If good then check fuel pressure if you haven't already. Disconnect EGR if equipped, test drive. If everything checks out then it's probably safe to assume carb is lean and will need o-haul.
Ls85c10man
