HELPP!! Annoying cab corner trim
GeorgiaK10
Warner Robins
Grayson
This stupid little cab corner trim just randomly fell off in my drive way. I had no clue how to put it bqck on. Tried a screw driver and messed up my brand new paint:( any tips or trick would be greatly appreciated:)
-grayson
The88
Mhmm
South Louisiana
ThatGuy
pics say a 1000 words. Which trim panel?
GeorgiaK10
Warner Robins
Grayson
This isnt the peice off my truck but it is almost identical.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
There should be a bracket with a screw that attaches to the trim behind the emblem side, it goes through the small hole on the cab, and there should be a speed nut back behind the cab, you have to stick your hand up in that corner where the speaker is to get it on or off. The nut might have just came off, or the screw broke off with it.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
If Val's explanation isn't clear enough I suggest you have someone else do it for you.
GeorgiaK10
Warner Robins
Grayson
Thanks for the help val! I was able to get it back on this afternoon!
spartantx117
