Help With Factory Cruise Control For 78
andym22
NY
andy
k25
Adding factory Cruise control to my 77. Can someone post a photo of where the wires and vacuum release go through the firewall? I know there should be a dimple on the firewall for drilling but can't seem to located it.
Jeff Brown
Redding, CA
Jeff
Scottsdale C20
Don't know if you've found the answer yet but here it is on my '77 Camper Special w/fact cc. As you can see, it's bundled with the wires for the cruise.
I have an 80 K25 with factory CC... mine goes through the same way wit ha single bundle of wires and large vacuum line going through that same spot.
andym22
NY
andy
k25
Thank you for the help.
Now I'm trying to figure out how to mount the cruise control servo bracket with a holley carb one bolt goes through the head, but there are two holes that would have attached to the rochester control lingage bracket. I don't see anything from holley to adapt the universal linkage bracket to attach the servo bracket. Does anyone know of someone that makes this mounting bracket?
Wrenchersllc
