Help w/ steering
firebane
Calgary, AB
Curtis
Oh yes I see what you are getting at. I mean to remove it completely off the steering shaft lol. Sorry.
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
So, in theory should I remove that, find one that fits my box? Or just try and see if the box is incorrect and go from there?
I hate to sound like an idiot but this is my first time messing with this.
Georgeb
Wisconsin
George
K10 Burb Z71
Are you sure there it's lined up with the splines correctly? If so and it really doesnt fit then you will need to either get the correct gear or a different joint. I would install the rag joint on the bench and then put the box on the truck.
chengny
Make sure that the two components are made to be assembled together:
Measure the ID of the coupling flange bore and measure the OD of the stub shaft. Then, if they are equal, verify that the spline count is the same for both. Finally, if there is a surface that is machined flat on the shaft, check that it is the same width as the corresponding flat in the flange bore.
How far - if at all - can you get the shaft into the flange bore? Did you check for foreign objects in the bore, distorted splines in either part, that the shaft is true, etc?
laurentj23
cartersville
Laurentius
k1500
It is easier to just replaced the whole steering shaft with u joint. You can pretty much fit any size spline since it's adjustable.
Camar068
10 yrs Air Force
I'm sure you noticed the Jeep mod. It made a huge difference on my K10 and was cheaper to do than the rag joint cost. You should be able to find one at a junkyard for $8-15.
87ScottW
