Help. Issue with 700r4 on truck i just bought
Jared Albanese
Fremont ca l
Jared
Truck is a 86 c10. 305 700r4. Runs amazing. 108k miles. Engages in r, and all forward gears, but habe to rev super high to get it to creep forward on driver side there is something that goes into tranny on the side thats a lil loose. There is also a slight whinning noise when its in gear and revving i have concussion now and my girl wont let me under to get pics and tiggten up the piece ill get a pic of it when ahe is in shower and post it. Could it be torque converter? Had a leak from that part on side and previous over says thats the issue. Any ideas or opinions?
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
That's the throttle valve cable. It controls the shift points. If it's loose, then plastic retainer is likely broken. Do not drive the truck, order a new cable. They are a pita to replace with the transmission in the truck.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
He’s right. The only way I was able to do it was to pull the cable around to the other side of transmission to put tension on the two ends that hook together. It’ll make sense once you take the cable off.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
How is the fluid level? First thought was the Speedo connection. It'll leak there too.
CSFJ
Throttle valve cable should be on the passenger side, not the driver side.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Check the fluid level in the truck first, and x2 on the TV cable being on the passenger side of the trans. It then runs up and over the trans to driver side of the throttle body.
Do some reading on this article to give you a better understanding. I had to change my TV cable while on the truck and its a pain. If you're concussed currently I wouldnt suggest it since you will be laying down in different positions with your head up trying get the little hook in the bottom.
http://www.tvmadeez.com/article/
If it is your TV cable DO NOT DRIVE IT. You can fry your tranny in a short distance. Pay for a tow to a shop, have a friend do you a favor, or just wait if you cant fix it now yourself.
JOD26
