HELP Holley super Sniper 4 bbl woes, 502 ci big Block
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I'll post a video shortly... I got some things to fix here and there.
Exhuast leak at the primary, ps pump apparently got overlooked on one of its bolts to hold it to the block, couple other really small details.
I will post a video here and on my build thread.
Ain't a damn thing wrong with this ol holley!!!!!!!!!!!
The88
Mhmm
South Louisiana
ThatGuy
I would "like" your video but you didn't rack it hard enough.... Congrats on popping her over!
Awesome!!!
Vbb199
Salisbury NC
Vince
Not with a exhaust leak at the primary.
I have to fine tune some things on it, get the timing and idle correct, once all that is safe and it's good and broken in, I'll have a video of it at 5000, or higher.
The couple times I did Rev it up, it was just at 1800.
Vbb199
Salisbury NC
Vince
Thanks again @bluex for the telephone call assist, and thanks @bucket for your help and the reccomendation on bluex's expertise
Vbb199
Salisbury NC
Vince
Quite simply.... The reason it wouldn't fire was the idle screw was adjusted WAY to far closed.
Had nothing to do with varying voltages, or any of that other bs I originally thought.. Once I started opening the throttle blades, it came to life.
I was thinking like a old school carb and barely having that cracked, wasn't considering in the idle air control valve in the whole mix.
I DID inspect the plug wires, only to find the 1 nick in the wire, I wrapped it up real tight.
Timing was set originally at TDC, 10 degrees BTDC, I ended up advancing it, probably 3-5 degrees.
I don't have an assistant to turn it over while I put my timing light on it, but I figure I'm somewhere 13-15 degrees base timing.
bluex
Spartanburg SC
C15
Here's the video I mentioned about setting the idle speed/IAC percentage
Vbb199
Salisbury NC
Vince
Have to straighten out the Exhaust and minor other details, then I'm gonna go ahead and fire it up and let it warm up to operating temperature, get the idle set right, all that.
It's gonna be fun!
Carb'ed Vortec 350
That sounded awesome
Doppleganger
OH-MI: Just like it sounds
As soon as I heard that rumble at start up all I could think of was
RED
RED
YELLOW
GREEN
Congrats dude.
Vbb199
Salisbury NC
Vince
RED
RED
YELLOW
GREEN
Congrats dude.
Thanks man!
Turns out this crazy mf could get it running amongst a cluster f of wires , with a little help of course...
That was all the motivation I needed to continue the project, next milestone... Making it run and drive.
Carb'ed Vortec 350
Thanks man!
:grd:
78ALB
