Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
The diagram shows it going to Tach, so I think you should be good... they might have meant coil(-) on a different ignition setup. I'd try it like you have it with the things you have fixed first, then try switching to the negative coil hookup as a last resort
Battery is still juicing up... I just watched a video of a guy cranking his 350 up, when he went to crank it, the display showed "syncing"
So I think it syncs everytime you crank it up.
I also opened the idle screw up a bit... Or in other words, opened the throttle plate.
