Headlights and dash lights problem
Farmerlane
waverly ia
lane
We are not able to switch from high beam to low beam and when we drive at night the dash lights don't work
what do you guys think?
we have a 1986 chevy k10
72chevy2door
Florida
Jeff
1500 Sierra Classic suburban
Either the dimmer switch went out on the column or the headlight switch went out. I'm thinking more of a headlight switch because of the headlights not working.
Farmerlane
waverly ia
lane
my headlights work i just can't change the brightness, my dome light works and my parking lights work, but my dash lights don't work at all, and how do i switch it from high beam to low beam again, maybe I'm not doing it correctly!
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
You turn on the headlights by pulling the headlight switch in the lower left of the dash 2 clicks out. High/low is changed by pulling/pushing the multi-function switch on the column (the turn-signal switch). The dash lights are controlled by twisting the headlight switch knob on the dash left and right. It is possible to click the dash lights off by turning one way, or to click the dome and courtesy (if you have them) lights on by turning the other way.
Snips71
