harmonic balancer
dusty1964
tremonton utah
dusty
my harmonic balancer needs to be replaced . i went to pull one off a used engine and it is a couple of inches smaller diameter can i use it in place of the 8.5 inch one. thanks
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
You should be able to, but a new one is like 50 bucks
dusty1964
tremonton utah
dusty
keith there are 2 common reasons harmonic balancers need replacing > one is the oil seal will wear a grove and then you get a oil leak . this is why mine needs to be replaced"" #2 reason is the rubber that holds the balancer together will start to deteriorat
Keith Seymore
Motor City
Keith Seymore
4.3L
Understood.
Just making sure it wasn't "because I feel a vibration" or "It looks funny".
K
mine looks a little funny, but im not replacing it because of it. i cleaned the engine so if its leaking oil i can see. too many things leaked oil like intake, ps, valve covers, coolant, me filling fluids and spilling, water, dirt, me spraying fluids, hoses popping off, etc. so i figured clean slate would be much more reliable
illmanners
Idaho
Phil
C-10
All traditional small block Chevy V8s except for the 400 use a neutral balanced harmonic balancer. The 400's harmonic balancer has a counterweight built in it.
Common engine building practice (including the factory's) for all non-400 applications is to balance the harmonic balancer to neutral balance by itself. That way all balancers are interchangeable without further balancing work.
When you buy a factory balancer or a decent aftermarket one it is already neutral balanced.
+++NOTE+++ unless the balancer has been changed before, and is still the factory balancer, the larger diameter balancers were typically used on 4-bolt main engines so there's a potential "plus" for you..
Jdk412
