Gm 350 #10067353
Skweegle89
Oklahoma
Oh & the 305 is running the Qjet. This may be rebuilt & used. Depending on a rebuilder or my time if I'm doing it.
There is a member on here that rebuilds qjets for a living.
68post
Indianapolis
Tim
454, TBD
This is a great bargain in my opinion ; http://www.summitracing.com/parts/nal-12530282/overview/
Vortec heads, 9.4-1 compression, one piece rear seal, and a roller cam ! What's not to like ? :party36:
For $30 more you can buy the 4 bolt main version.
If you do change the cam in it - the HT383/350 Ramjet cam can be bought new or used for cheap, and will give it 350 HP.
Just add a performer vortec intake ( I bought mine for $60 + shipping - used )
$.02
olemans85
South Jersey
Aden
358 roller
Tim,
I didn't think this engine would fit into my truck. I'll check into this to see if it will.
Aden.
rich weyand
Bloomington Indiana
Rich
One issue is that there is no provision for a mechanical fuel pump on that engine, so you need the electric fuel pump(s) in the tank(s), or some in-line setup.
olemans85
South Jersey
Aden
358 roller
Rich,
I'll run the Qjet. I'm looking for the 4 bolt main option now on the Summit website
Aden
firebane
Calgary, AB
Curtis
Rich,
Aden
Don't bother. Get whatever you can afford. There is no proven evidence 4 > 2
olemans85
South Jersey
Aden
358 roller
GM crate engine #12530283 vortec heads 4 bolt main. Anyone ran this carbureted?
rich weyand
Bloomington Indiana
Rich
Rich,
Aden
Whether you run a Qjet or not, you still need a fuel pump! There is no mechanical fuel pump location on these engines, so you have to do something electrical for a fuel pump, either in the tank or in the line.
olemans85
South Jersey
Aden
358 roller
Well after some research, Ill be staying with the original GM crate engine #10067353
with the Comp Cams 12-235-2. Using the GM crate engine #12530283 with a mild Comp Cam only produces 5% gain in HP & TQ at a greater cost.
Aden
68post
Indianapolis
Tim
454, TBD
Aden
Vortec heads, a roller cam , and what's probably a point and a half of compression you think would be only about 15 hp ?? I'm guessing 40 - 50 hp !
rich weyand
Bloomington Indiana
Rich
But not much more torque. In the typical rpms of daily driving, the 350/260 crate with the 12-235-2 cam does very well. 410+ lbft of torque at 2500 rpm is a lot of fun to drive, and hard to beat.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
If you have time I am all for rebuilding, establish a good friendship with a machinist and your set. If the truck is just a fun vehicle and not critical to day to day life I would just buy some books, read about it and have a good time.
I actually spent more rebuilding my big block than just ordering a fresh crate 454 but it was alot of fun. A crate engine costs everything at once (unless you have a credit card, I dont) but rebuilding lets you spread big purchases out over time and the end result is a one off custom engine you know everything about.
There is a certain satisfaction to it you only experience if you do it yourself. Transporting yourself in a vehicle you rebuilt the engine and transmission in is pretty cool, a ton of satisfaction.
With that being said, if my Impala SS threw a rod because I was driving it like a moron there would be a crate engine on its way here. Its the family car so we cant wait a year for me to assemble a 383 stroker for it.
olemans85
South Jersey
Aden
358 roller
The HP gain is approximately 30hp & TQ is 15 ft lbs. I will be visiting the local machine shop. For their input.
350runner
tx
Ceasar
I went with a 350 from a local block built to my specs tho I have them a chimp cams 260h everything else came from them 80k later it still performs like day one. Drive hard my friend.
Where is the like button...
Obullard74
