Gen V big block valvetrain
82ChevroletK20
Darlington
Cody
Im looking to put a different cam in the gen v big block im building. I was just wondering how much lift the stock valvesprings could handle or whether i should upgrade. Any info is appreciated
Thanks, Red
Rickf
Grafton NH
1974, 1954 & a 1937
The cam manufacturer should be able to recommend springs and related hardware.
The valve guides can only handle so much lift before they need cut down. It's also a non-adjustable valvetrain and converting that is another can of worms.
Besides that, the stock springs are good for a stock cam and nothing more.
82ChevroletK20
Darlington
Cody
Ive already converted the non adjustable valvetrain arp makes conversion studs
How much lift could i get away with before i run into the valve guides?
TerColHan
Pasadena, Tx
Rod
Suburban 2500
82ChevroletK20
Darlington
Cody
TerColHan
Pasadena, Tx
Rod
Suburban 2500
I think the rotating assemblies about the same on the base engines so you'll still be limited on how much lift to run I think the biggest difference you'll have is which lifters to run. Gen 6 is factory roller but don't gen 5's still need retro-fit rollers?
82ChevroletK20
Darlington
Cody
I want a hydrualic flat tappet
TerColHan
Pasadena, Tx
Rod
Suburban 2500
Then the cam listed in the article won't work for you, gen 5 upgrades are pretty limited by the stock configuration.
This build got pretty good results but they did a full rebuild and bumped up compresion to do it.
http://www.cpgnation.com/power-for-peanuts-gen-v-big-block-power/
This site offer some good advice for dealing with the limitations of a stock gen 5 and what can be gained on a budget without going to a roller setup.
http://tbichips.com/?page_id=87
or with one..
http://tbichips.com/?page_id=135
Obullard74
