Gauge warning light question
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
I just found a factory tachometer and it has a blank space where there should be warning lights. Since I have never taken apart a GM gauge pod before, I have NO idea how to replace it. Do I remove the one from my old fuel gauge and attach it to the tachometer somehow? And if so how is it done?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Are you trying to install the factory tach where your current gas gauge is or did you find a full cluster?
You will need to do some plastic removal to get it to fit. The warning light plastic fits in a space in the housing, not the gauge itself.
Yah, the engine light, parking brake, 4wd, turn signal labels are all plastic pieces that sit on pins in the gauge housing, and they have gaskets, and the gauge goes on top and gets screwed down tight over them. I swore I posed pics of that stuff here somewhere... :think:
FRANKENTRUCK
By The Sea
Pierce
This is a single tach that I am installing in a cluster where the gas gauge is. So the warning light film is attached to the housing not the gauge? That will help a great deal.
Yeah, they just sit on plastic pins molded into the housing, there are holes in the film, they slide on with a foam gasket behind them and the gauge pushes against it. :)
I am still trying to find pics from mine.
FRANKENTRUCK
By The Sea
Pierce
The tach arrived today and I installed it in the pod. Thanks for the advice! It made me aware of what I was getting into before I opened the pod. I have put together gauge pods for my old 74 Dodge Charger and my 73 Plymouth Satellite but this was my first attempt at a GM. What a difference!
sparky77
