Gauge/Idle
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
im having the same issue, ive had the issue before, then it stopped, and now im having it happen again, and i have no idea what it could be this time
You should ceck the wiring behind and under your distributor. The fuel pump wiring runs to the oil pressure switch back there. Wiring might be chaffing.
4speedburb
Waukee
1500 Suburban
i will definately check that 2maro! i was thinking i had a bad ground somwhere
4speedburb
Waukee
1500 Suburban
ok so its right behind and under the distributer?
Jims86
Patterson,Ca
5.7 TBI
Yes, you will see them going into the oil pressure switch.Check the alternator wiring as well.
4speedburb
Waukee
1500 Suburban
ok sweet thank you!
guillermoariast
