Gas gauge
My79c10
Usa
James
Can someon help with a VHX Dakota digital. I can't get my gas gauge to read correctly. Can someone show the wiring for a 79c10
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Check the grounds first, there should be a sending unit wire grounded to the frame rail near each tank.
Inspect them & make sure they're clean and bolted down on a clean rust and paint free spot on the frame.
The grounds are hooked to the sending unit with a plain uninsulated spade connector on the top of the tank, clean those if you can get to them.
My79c10
Usa
James
Thank you .. I'll check it.
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
Also, confirm that you set the gauge to read 90 ohms.
Edit - Not sure if the 79 needs the 90 ohms. Sorry bout that
redneckgames
