Fuse Block/Wiring Harness
Ken B
indiana
ken
Does anyone know if a fuse block and wiring harness for an 83 k10 is the same as a 81 c10?
Found a used k10 set up and was wondering if it would work on my 81 c10.....
crpntr78
Missouri
Should be pretty much identical.
Ken B
indiana
ken
i was thinking that too, my fuse block has some age showing on the engine side,, heat. If it all matches up I personally would like OEM stuff even if it is used...plug and play
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I am having an issue with heat from my goodwrench 350 in my 83 C20, and I suspect it may have damaged the engine side of my fuseblock adding to my lighting issues.
Thanks for making that point and making me aware of something to look for.
Now, to scrounge a good shape OEM engine side harness.......
Ken B
indiana
ken
[QUOTE="AuroraGirl, post: @gmachinz he may help[/QUOTE]
more information please
more information please[/QUOTE]
He manufactures new harnesses, iirc he makes a new off-the-fuse-block harnesses. i believe 2 plug into it? a forward and rear harness???
504SquareBody
