Fuel tank selector switch
73 Chevy1
Central coast
Steve
I have a 78 Chevy truck. I bought a new selector switch and bezel but can figure out how to mount it. It appears the holes the bezel snaps into is to loose? Are the holes too big? It was fine when I took out the old one. Will not fit snug is there supposed to be a clip on the back or something that holds it into the dash?
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Will the new switch work in the old bezel?
squaredeal91
Greg bush
1991 SB
Good question. I wonder if you got the correct switch, the plugs are different tho. Do you have the actual wire plug or do you just have crimped female connectors on it in the correct place?
73 Chevy1
Central coast
Steve
The switch plugs in and works fine it’s the bezel that doesn’t hold the switch in place when you align it in the two holes. Seems like the holes are to big or the bezel little plastic things are to small
squaredeal91
Greg bush
1991 SB
Is it possible to get pictures of the parts?
73 Chevy1
Central coast
Steve
This is my switch and bezel
squaredeal91
Greg bush
1991 SB
Does the switch fit in the dash good? Problem is with the bezel? Sometimes Aftermarket don't fit like it should
73 Chevy1
Central coast
Steve
Switch is fine I will have to try another bezel the one I got was from lmc maybe classic has something different
Doppleganger
OH-MI: Just like it sounds
I had similar issues with other car switches in the past.....wound up cutting thin strips of black tape and wrapping the bezel to make it fatter and to fit tight.
Aftermarket 'fit' is a pig in a poke anymore.
AceHanlon
Halifax, PA
Logan
When I replaced my fuel selector switch it came with the bezel and the switch and snapped right in.
73 Chevy1
Central coast
Steve
I bought a 10/32nd threader and put threads on the back of the bezel. Bought some nuts and screwed it on works great. Thanks for the responses.
alysco
