Fuel sending unit question
kychevy
Guys, I am sorry if it’s been asked b4 but I’m a little stumped with the fuel sending unit. 87 TBI and adding 2nd tank that was removed. Bought the crossover lines and had new tank plumbed but then took a look a look @ passenger tank and the 1/4” line is the vapor line. Reason I state this is the crossover lines I bought from LMC has the 5/16” metal line as the vapor. I was under impression 3/8 was feed, 5/16 was return and 1/4 was vapor…..is that wrong? That metal line has me 2nd guessing myself now.
kychevy
@Ronno6 The correct sizes are
Fuel line 3/8"
Return line 1/4"
Vent line 5/16"
So your truck is setup correctly. Whatever the other thing you read was wrong.
So, I finally found this but another question is why is my pollak selector valve 3/8” and 5/16” if 1/4” is the return?
SquareRoot
I just went thru this converting my 85 to EFI. Replaced the entire system. The 1/4 is the vent. 5/16 is return. The 6 port Pollack valve has 5/16 and 3/8 barbs. The vent lines t into each other and run to the vapor cannister .The vent line does not go thru the valve. The 3/8 has one input and two outputs (left or right tank). Same with the return, thus 6 ports. Is this an 87 factory TBI truck with fuel pumps in the tank? Earlier trucks with a carb and mechanical pump are slightly different, don't confuse the two.
kychevy
I just went thru this converting my 85 to EFI. Replaced the entire system. The 1/4 is the vent. 5/16 is return. The 6 port Pollack valve has 5/16 and 3/8 barbs. The vent lines t into each other and run to the vapor cannister. Is this an 87 factory TBI truck with fuel pumps in the tank?
Yes it is. It’s kinda a Frankenstein truck and thought had it figured out but started seeing other info so threw me off little bit. Thanks for the reply
SquareRoot
See my edit for added clarification.
SirRobyn0
Rob
I could be misremembering the lines, also my truck is carbureted. thanks Mike @SquareRoot for correcting the line info.
ali_c20
Austria
Alexander
C20, K5
I installed new sending units on my 74 c20.
Without return: Fuel line 3/8" Vent line 5/16"
With return: Fuel line 3/8" Return line 1/4" Vent line 5/16" is the setup for the carb trucks.
When you look at the sending unit the vent line has some kind of valve thingi on it.
https://www.gmsquarebody.com/threads/dual-tank-questions.1567/
SirRobyn0
Rob
michaelmarine53
