Fuel Pickup
Frankie
Three Rivers, Michigan
Frank
R3500
Doing a frame off on my '89 square body. Swapping a carb'd 454 for the 350 tbi. Tanks and pumps are junk so along with everything else they are being replaced. My question is since the tbi needed the return line hence the 3 port pickup, can I switch to the 2 port since I don't need the return line? Also is the 6 port tank selector switch usable or will that need to be changed to the 4? Getting parts to put her back together and the less plumbing the better. lol
HOTFOOT
northwest ct
michael
gmc k3500 srw
My 80 k3500 400 sbc has 3 port sending units, just get a 3 port pump and sending units they say it is less likely to vapor lock.
75gmck25
Northern Virginia
Bruce
GM also used a return line on carbureted trucks ( my ‘75 has one) because having the fuel return instead of dead-heading at the pump keeps the fuel cooler and helps prevent vapor lock. Squarebody body engine compartments are large and usually aren’t as hot as a smaller vehicle, but vapor lock is still possible.
Bruce
Frankie
Frank
R3500
Didn't even think about vapor lock, had that happen in the past. Not fun. 3 port it is, thanks.
Gage T
