Fuel Lines 2wd vs. 4wd
Rohrs84GMC
Pacific Palisades, CA
k1500
Hey guys,
Quick question. Does anyone know if there is a difference between 2wd and 4wd supply fuel lines?
Background:
When looking at LMC, the description they have only shows for 2wd. I have been royally bit in past thinking there was no difference when there was and don't want to make same mistake.
Here is the link: http://www.lmctruck.com/icatalog/cc/full.aspx?Page=47
I have an 84 1/2 ton 4x4
Any thoughts on this would be greatly appreciated.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
I'd buy them from some place other than LMC to be honest. they tend to rape you on freight. have you checked rockauto.com? They have a much better search tool, broken down by individual truck models.
Rohrs84GMC
k1500
I will look into both! Thank you guys. I was so tunnel vision I was stuck on the LMC thing.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
I would not be terribly surprised if you could even check your local Napa, Car Quest, or Advance Auto and find the parts as well fwiw.
aidenB15
