Ford trucks having problems filling up with fuel
bigtalljohn13
Illinois
V20 Suburban
350ci
If any one one here happens to own a Ford truck gas or diesel '99 and newer, you may have experienced it being difficult to fill up with fuel. I own a '05 F250 Super Duty with the 5.4 gas engine and for the past year every time i try to put gas in it, it shuts off every half gallon and take for ever to fill up. I did a lot of research and found that it is a common problem and supposed the fix is to replace the $300 charcoal canister and possible the purge valve. Well tonight after only getting $20 in it, it finally ticked me off so i did some tinkering with it. The "fix" is quite simple. All you gotta do is take apart the purge valve and clean it. The is a part that has an orange rubber flap (like a one way check valve) and its has a screen that is around it. I didn't realize it was a screen until i cleaned it off with break cleaner. I cleaned the rest of it up and put it back together and filled my tank up without it shutting off once. If you have this problem give that a shot before spend the money.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
The newer mustangs do the same thing. My 05 did this before I sold it and it worse in cold weather, so you have to screw with it while you stand out there and freeze. It quit when the weather turned warm again. I never bothered with it before I sold it.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
we use furd pick ups in the mine i work at they got plugged all the time.
i came up with the idea to run a hose off the canister up behind the tail light and put a pcv filter on the end.
the pcv filter can be changed alot cheaper than the canister.
it has worked for about 3 years not a single canister has been plugged since.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Funny you mention that, the mine I work at also uses all fords and they all have the exact problem. Most every van and pickup does it.
88SQDRW
