exhaust manifold donut
Layne02
Ga
Jeff
R1500
Hi everyone, my question is about the exhaust manifold donut gasket. A while back I installed a reproduction stock exhaust on my 87 . I ordered new donuts but they were different from mine , seems like they had a metal sleeve on it and mine do not, so I reused old ones. Well now I have decided to put a dual exhaust on it and was wondering if anyone has ordered new ones and where they got them. Thanks
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Did you consider headers?
yevgenievich
Viktor
sad
very sad
less sad
Check for 95 g20 van. I have one g20 manifold and it is different from stock gasket.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Yeah and it's dissapoing to say but at various points over the smog era GM really did change the manifolds some from year to year and even though the askets should be the same it always has made me question their fitment.
Rusty Nail
Rusty
350sbc
Yes. I have found that there ARE different sizes. I think I was offered two.
I bought mine @ O'Reillys.
Last time I bought donut gaskets, the parts guy just had me go back to the parts shelves and match one up. He said it was a waste of time looking it up by application. He was a good parts guy.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Donut gaskets come in two configurations.. One has a steel sleeve attached to the I.D. and is approximately twice the depth of the gasket.. The sleeve fits into the exhaust pipe and prevents the donut from collapsing... The other type donut doesn't have the sleeve.. It requires an exhaust pipe that has the sleeve attached inside the flare..
The exhaust pipe size and configuration, the donut gasket, and the exhaust manifold all have to match in size..
rpcraft
Robert
Jimmy
LS 6.0 364 CID
I didn't think to ask because I ditched the stock stuff ages ago but I had to go back and look at some pictures and remind myself are you talking about the drivers side or passenger side? The reason I ask is the passenger side had that thermo-valve thing on anything up to 85 at least (because I had a 77 and it had it until I swapped to headers, and then my 85 had it too until i tossed the exhaust in the trash too... If you are missing that valve it will never mate up properly and I think that requires 2 gaskets??? Someone help me out here.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
You're talking about the heat riser valve.. Manifold to heat riser valve requires a flat "three sided" gasket.. A donut gasket is used between the valve and the exhaust pipe.. The studs in the passenger side manifold are longer so that everything can be "sandwiched" together.. The early valves were spring loaded.. the shaft for the "flapper" part is off center.. The spring holds the valve closed and exhaust flow pushes it open.. Later models have a vacuum operated valve.. In the past, I have seen donut gaskets that are flat on one side and tapered on the other.. All the gaskets I saw in this configuration had a sleeve sticking out the flat side..
Later fuel injected GM's often had a dummy (empty) heat riser. Like TPI Camaros and I think the TBI models too. Can't remember for sure. I don't remember if the trucks had them or not. Headers for all!
Layne02
Ga
Jeff
R1500
Mine were like the one that has the metal sleeve but did not have the sleeve. They slid over the exhaust manifold outlet. So the metal s!we've was in the way.
twinturbo427
Florida
Phil
Suburban
Always save the flanges and at least 6" of pipe stub if reusable. You can save some bucks at the exhaust shop if they don't have to make them.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
put some long tube hedders on the thing and get some low end grunt. maybe 30 ft lb of torque. thats real bang for your buck.
guillermoariast
