Engine to Firewall Ground
texasmike
Conroe Texas
I just discovered that the copper strap on the left rear of the engine is completely broken (separated) from the fitting that attaches to the head. Since truck runs fine and everything works like it should, is it safe to keep driving the truck until I get it repaired? The bolt in the head is going to be a bitch to remove.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have seen lots of those ground straps either broken or missing. Ideally, it should be there. Just make a ground strap from 10 gauge wire and a couple of ring terminals. Find a bolt or stud that’s easily to reach on the intake manifold, problem solved. Just make sure to clean any dirt or paint from the surface for a good connection.
texasmike
Conroe Texas
Thanks Matt, that's what I'll do.
Catbox
Peter
C20 Silverado Camper Special
You will be fine enough.
Our previous owners mechanic cut ours off many moons ago and left it to hang limp and sad.
We are going to replace it here in a day or two just to make the ground path as good as possible.
Nasty-LSX
TogetherforeverCovid19
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
you can buy ground straps anywhere.
PeteJr
NW MS
GMC Sierra Classic 1500
Now that I have aluminum heads, intake and of coarse the transmission, what's the best place to attach a ground wire on the engine?
Aluminum isn't the best conductor.
Aluminum is an excellent conductor. They use to make house wiring out of it.
Engine body and frame should all be grounded,mystery problems can appear without all 3 grounds. Remember the engine is on rubber mounts,the cab is on rubber mounts. So Engine,frame and body are theoretically isolated from each other.
PeteJr
NW MS
Well, that is true, forgot about that, but remembered everyone saying don't use it in MY house.
Thanks for the info and reminder, Richard.
BRetty
Los Angeles
Franklin
Ideally there should be a ground strap or connection from the engine block to the firewall. There's a bolt hole drilled/tapped in a V8 block right behind the #8 cylinder for exactly this reason. Of course, getting to that location is very hard, best to have a 6-year-old kid wiggle in there to do it. If you don't have any little kids handy, adults can do it with much scraping and cursing.
While your heads may be good conductive aluminum, remember you have a head gasket that is specially designed to isolate the head from the block. best to have a solid ground connection to the block. Your spark plugs depend on that ground or some other ground to fire. More common ground points can only help.
The ground from the head to the body is for electrical noise.Your engine should get its ground directly through the negative battery cable,to the block,because your starter and alternator are the most amperage dependant components on your vehicle. Body ground and frame ground can be to engine block or negative battery terminal. All other accessory grounds should be to body or frame.
84GMCSierra
Central Arizona
C2500
That's what is on mine on the right head. Might hold up longer than the copper braided wire
Scott91370
Burleson, Tx
Scott
Sierra1500
I made sure I would not have a grounding issue.
Battery to Frame - 4g
Frame to Engine - 4g
Frame to Cab - 4g
Frame to Bed - 10g (maybe 8g?)
I don't have the one from engine to cab though.
loki1978
