Engine to Chassie Ground
frwgt350net
California
frank
Engine to Chassis Ground
Could anyone tell me where the engine to chassis ground wire would be located on my 1980 Chev truck.
GXPWeasel
Kansas
Greg
1982 | 2015
Sierra C15 | Silverado Z71
5.0 | 5.3
If I remember correctly, on my '82 with a 305, it was on the back of the head, to the firewall. Not certain that's the correct one you're wanting, since the firewall isn't the chassis. I did pull a grounding strap off of this area on mine though.
frwgt350net
California
frank
Yes, I think that is the one I’m missing. The bolt was replaced in the head but without the ground wire. I am hoping this will help with my inaccurate gauges. Probably not.
Scott91370
Burleson, Tx
Scott
Sierra1500
Engine to body is done from rear of passenger head to firewall.
Engine to chassis is done alternator bracket to passenger side frame.
Wouldn't that be the alternator bracket down to the frame by the fuel pump area?
That's where mine is on my '80 K25. Large ground from alternator bracket to frame near fuel pump. Small braided strap from the back of passenger head to firewall. I also have a large ground from the intake manifold bolt on the drivers side to my Aux battery ground post.
Washington
Main grounds are Engine to chassis (frame), pick a spot, but alternator bracket is common. Battery to engine. Engine to body (firewall). Bed to chassis (frame)
Other's (after disassembling most of my truck body). Gas tank fillers to body (I think). Tail lights to body.
Aside from individual components in the cab and engine bay and accessories I think that's about it.
Battlac40
New Mexico
James
K1500 Sierra Classic
Back of the motor to the firewall, the alternator to frame, trans to frame
nathanjohnson85
