engine swap project
idahovette
Weiser Idaho
Perry
K20-K10
My glasses are always full as I brew at home. Anyone else following my mechanic adventures homebrew? I have a killer recipe for a Edmund fitzgerald clone, and a irish red that is to die for at 9%
Aw, crap you're too far away. I was gonna be your new best friend!!!
waterpirate
delaware
v10
5.7 tbi
Happy Mothers Day!
My beer glasses were empty this a.m. and my eye glasses were on. Flex plate installed correctly, starter fits fine. Re installed all belts and hoses, radiator and supports and battery. Truck is dead electricaly. Put battery booster charger on system and still no power. No lights, no horn, no nothing. Any ideas other than going back through and making sure all my grounds are good? As always the brain trust hear is greatly appreciated.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Check for 12v on both sides here.
waterpirate
delaware
v10
5.7 tbi
Thank you, I was not prepared to get as far as I got yesterday. That means I did not have my test light or volt meter with me when I attempted to start. Will try and get there this week after work in the evening to keep pushing the ball up the hill.
waterpirate
delaware
v10
5.7 tbi
Got to the mechanics shop today after work. I verified all 4 of my grounds as being good. Radiator support, alternator bracket, copper braid to fire wall, and copper braid to rear of head on passenger side. All good. I also have power going out to alternator.
I have no voltage on either side of the junction in your picture. Is that a fusible link in the wire leading to the junction?
Jrgunn5150
Ionia Mi
J.R.
6.slow
Yes, check the large post on the starter.
waterpirate
delaware
v10
5.7 tbi
ROFLMAO!
So I checked for voltage on the starter and got zip. Was preparing to remove wire from battery to starter to verify continuity when I realized it was on top of the front diff where I had tucked it and never re- attached it. Attached the wire and cranked the engine over and it is alive!
Jrgunn5150
Ionia Mi
J.R.
6.slow
ROFLMAO!
In the real world, these things happen to all of us lol. It's only on reality TV where they have 8 minutes to do a frame off restoration and it fires on the first try lol.
Congratulations!
waterpirate
delaware
v10
5.7 tbi
So on to my transmission cooler lines. Could only run the engine a minute before they started puking. I am calling the parts store tomorrow to see if they have a listing for replacements. If not are the lines the standard 5/16 tubing like I saw in a thread for the th350, I am running the 700r.
Thanx in advance!
Yep, standard 5/16 tubing and flare nuts. I've always made my own lines when I needed them. It can be a frustrating pain in the ass, but worth it when it's done tidy. And cheap too.
waterpirate
delaware
v10
5.7 tbi
Been keeping up with the new posts here, but work started to suck again thus the delay. Got some time Sunday to get after those tranny cooling lines. I bought stock straight tubing at my local Napa and got busy bending. Line 1 went without a hitch. First bend on line 2 and my 30 year old tubing bender broke! :( Got a new one in the mail today and it is onward to line 2, then on to my fuel leak. When will it stop? I am convinced that I angered all the parts held together by rust when I started man handling things to get the new motor in.
Jrgunn5150
Ionia Mi
J.R.
6.slow
The last little things always take the longest. That's why no one who actually wrenches likes those stupid reality shows lol.
waterpirate
delaware
v10
5.7 tbi
Trans cooler lines completed. Removed fuel filter and rotten line on frame and off to napa I go Monday.
waterpirate
delaware
v10
5.7 tbi
So as a interesting side note. I am at napa and get the filter and the " kit " to replace the lines. I rub some gunk off my old filter and I am pretty sure the f ing thing was in backwards? The rotten line is after the filter and on to the tbi. The rotten line was in the double bend after the filter after the rubber line. I am going to assume that we filter fuel from the tank on its way to the tbi. My filter was installed with the arrow facing the tank?
I have owned this truck for years and do not ever remember changing the filter. I may have back in the early 90's when I drank profesionaly. Or a tune up guy may have done it?
My thinking says the take out is backwards.
Thoughts?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I don't know if makes a big difference since is been like that for a while but, I would want the flow arrow pointing in the right direction.
78ALB
