Engine keeps dying at random
Johnnyz453
Jacksonville, FL
:shrug: recently I got the truck running again. Replaced the whole ignition system, a fuel filter, and sending unit. Was driving perfectly fine and when I pulled into school and started backing into my parking spot it died. Won't start again. Anyone know what the problem could be?
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Bad battery connection. Either at the battery or at the starter/ground.
Does it crank?
da_raabi
FloriDUH
Adam
c30
Check to see if you are getting:
1. Fuel at the carb. Could have a fuel pump problem or clogged fuel tank pickup
2. Power to the dizzy.
3. Spark from the dizzy to the plugs
Johnnyz453
Jacksonville, FL
Getting all of those. I have a 600cfm edelbrock carb on it with a built motor. I think it might be flooding out if I don't get on the gas for awhile like when rolling through a parking lot. Has a clear distributor so I know I'm getting spark
Georgeb
Wisconsin
George
K10 Burb Z71
So does it die like it just shut off or does it sputter out and blow black smoke? Can you catch it and keep it running my opening the throttle? How do you get it restarted?
Johnnyz453
Jacksonville, FL
Only has happened once before. It will just instantly cutoff. No sputter or anything
da_raabi
FloriDUH
Adam
c30
That really sounds like an electrical issue to me. If it were fuel-related it would cause physical issues like smoke, knocking, sputtering, etc etc. You'd know it is my point. Even a failed fuel pump would not just "shut-off" the engine. I'm thinking you may have a problem in the ignition circuit, possibly the ignition switch or something in between.
What you describe really does sound electrical to me.
Johnnyz453
Jacksonville, FL
I think its flooding. Only happens really when you dont touch the gas for awhile. I just replaced all the eletrical so i dont know how it could be that.
RangRayy
Kansas City, Missouri
ryan
r10
Well since you just touched the ignition stuff it's still possible to be the culprit. What happens when it does does your dash and lights still work when it dies? Do you get a strong smell of gas after it happens? If not then i doubt it's flooding. Possibly vaporlocking.
Johnnyz453
Jacksonville, FL
All lights work. Had a friend thats a mecanic test everything yesterday. Its loosing power somewhere in the distributor at random. Still getting constant power going into the distributor even when it kills the engine.
Georgeb
Wisconsin
George
K10 Burb Z71
So your saying you have confirmed a no spark condition right after it
dies? If so, how did you confim no spark? What do you do to get it restarted?
Georgeb
Wisconsin
George
K10 Burb Z71
Also please list out what parts have been replaced.
stlbob
St.Louis
bobby
91'
k3500 4x4 Burban'
You said it turns over freely..?? Try the ign module first GM's are bad for those.BUT most times the are either dead or they are not.I did automotive forever and id say maybe 3 times i have seen an intermittent module failure.
Scandia
