Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
So, I've got a interesting situation, not looking to do full electrical, just a few things.
I have a uncut firewall wiring harness that's original to the k5 (91), I have a cut up interior harness that's original to the k5 (also 91), I have a uncut 89 Subruban interior harness.
My goals:
Functioning instrument cluster
Functioning headlights, taillights, turn signals, and rear tailgate motor working
Holley efi working (just needs 12v source) + readings from engine temp, rpm's, maybe oil pressure
Dome light, and floor lights functioning on switch (don't care about door jamb switches)
My questions:
Can I take the original TBI harness(s) and do straight wiring
Example: oil pressure sensor to oil pressure pin on the cluster? (if that exists)
Or does the oil pressure sensor go to the computer first, then go to the cluster?
The cluster is cable driven speedo. Will that be a problem?
I'm running a 75 front end, and I have the entire wiring harness for all the lights and such, I cut it off the already raped truck with about 2 feet to spare. what's the easiest way to make it work with the 88-91 front end harness.
I don't really care if it looks like a rats nest of wires as long as I know where the wires are in the rats nest and what they do.
If you've followed the k5ton project, and are a little current on pricing , you'd know alot of money has went into it, so I don't want a fire LOL
I'm not a dummy, and I know how to use a multi meter, it's just a matter of "what goes where" and what does what.
Thanks guys!!!!!!
Sent from my SM-G965U using Tapatalk
My goals:
My questions:
Thanks guys!!!!!!
